Application Builder has wrong disc instruction in LabVIEW 2009
Just to note that this is a problem.  I was able to figure it out, but the instructions are setup for the cd method (before DVD) where there was a separate disc for each tool.
Now that everything is on DVDs, the instruction needs to be updated for building distribution installers for the required discs.
I was being asked for the Vision Development Disc which is actually a part of "DVD 3 of 5".
I was also being asked for Device Drivers Disc 1 which is actually "DVD 4 of 5" (NI Device Drivers).
Message 1 of 9
(3,571 Views)
Hi Chris,
In what form were you shipped the disks? Did you not receive the 2 platform DVDs?
Jeff | LabVIEW Software Engineer
Message 2 of 9
(3,536 Views)
Hello Jeff,
At the company where I work, we receive the Developer Suite DVDs.  I am unclear as to what you are talking about with the "2 platform DVDs".
Thanks for the response.
Message 3 of 9
(3,525 Views)
Jeff,
Please note that I have been successful creating the executable and installer that I needed.
I just wanted to state that the instruction for inserting the LabVIEW discs when creating the installer was incorrect.
Chris
Message 4 of 9
(3,524 Views)
We actually don't usually see the customer disks here in Applications. Are the only labels "DVD 3 of 5", etc. on them? Is there no subtitle that lists "Drivers" or anything?
Message 5 of 9
(3,492 Views)
My Developer Suite consists of 5 DVD's.  ( I don't have Vision, but I do have DSC)
The first 3 say DVD x of 5 (1, 2, or 3) and just has the title NI Developer Suite.
The 4th says DVD 4 of 5, has the title NI Developer Suite, subtitle NI Device Drivers.  (this is the only Device Driver disc, there is no #1 or #2, or ....)
The 5th says DVD 5 of 5, has the title NI Developer Suite, subtitle MSDN Documentation.
When I installed, I only required DVD's #1 and #4.  I haven't done any application building with these.
Message 6 of 9
(3,489 Views)
I think the instructions are correct for the regular distribution where there are only 2 DVDs and the Vision would be something separate. I suspect the decision was made to not customize the instructions for the Developer Suite distribution which would be a small percentage of users and most often, more advanced users. There are also different flavors of the Developer Suite that would make separate instuctions even more difficult to maintain.
Message 7 of 9
(3,480 Views)
Yes, I believe this is basically the issue. You could also install the components from online downloads, etc so there would have to be a service that tracks each individual component and where it came from. It probably could be a little more general, though.
Message 8 of 9
(3,451 Views)
Hi all,
It turns out there is a CAR already filed on this issue. Its number is 125575.
Message 9 of 9
(3,414 Views)
