I wish I knew what hit me.
All I did was to try and create an installer for an EXE for the enclosed VI. ( created with LV 7.1 )
After I tried to check the installation my woes began.
- After the installation was completed the exe never worked and said that DAQMX AI read VI was not found ???
- Every time I try to launch LV7.1 and LV8.0 subsequently , I get
a dialog which says that the lvruntimeeng.msi for LV7.1.1
is not to be found and asks me to locate it.
After all this I tired to create a simple EXE without invoking the
installer option. I tried to run the creayed EXE and I get a
message which says that " LV 7.1 run time engine not found "
Can someone help me and tell what is wrong with the Application
Builder. I have wasted lots of time reading the user guide and
other application documents and still cannot figure out how to
use this software.
Raghunathan
Raghunathan
LabVIEW to Automate Hydraulic Test rigs.
