Application Builder - Pb
I have this pb with the application builder when I use the imaq library.
Error 1 in Invoke node in Dist Chg and Save->Dist Build LLB Image.vi->Dist Build App Image.vi->Build Application.vi
Labview : invalid parameter or NI488...
Without any imaq vi, it is working fine...
(2,800 Views)
What version of LabVIEW are you using? If you are using version 5.1, this problem was fixed in the 5.1.1 update, which you can download from our website.
If you are using another version of LabVIEW, try mass compiling your VI library before performing the application build. You can read the on-line help in LabVIEW for more information on performing a mass compile.
Please let me know if you still have any other questions, and thanks for your patience on this issue. Have a pleasant day.
Sincerely,
Darren N.
NI Applications Engineer
(2,800 Views)
