Application Builder Lost
Hey Everyone,
Weird problem, I am coding mainly in LabVIEW 8.2 right now.  I was playing around with the demo version of LabVIEW 8.5, and I decided to get rid of it.  No problems, I restarted and loaded my project.  According to LabVIEW 8.2, I no longer have the application builder installed.  Has anyone else had this problem?
(2,982 Views)
Ok, more info.  I went to re-enter my code and here's the new problem.  I went Project Window > Help > Activate Application builder.  Errors 2 shows the box I get.  Errors shows the project windows showing errors on my build specifications.  I have the Full Development version, and now I can't seem to enter in my Application builder... sweet.  Any Ideas?
(2,975 Views)
Ok, I finally got it working.  I was able to determile it is a lost liscense file.  I tried to insert the afile, copy it, everything.  Finally the way that worked was to get the lisence file from a fellow developer and then it worked fine for me.  So if you have this problem, find someone else you know using LabVIEW to send you the file. Smiley Wink
(2,940 Views)
