Application Builder API Get/Set Version issue with RT Linux PXI Package
I am using the App Builder API to create RT Linux packages in LabVIEW 2019 for PXIe.  It looks like the get/set version VIs have a bug which uses the wrong xml tags in the project file for RT Linux PXI.
I can set/get the version without error (it reads back what I write), however when viewed in the project, the version is unchanged.  When viewing the project as an XML, there are tags which match the version I wrote using the API ("Bld_version.major", "Bld_version.build", etc.) as well as tags that appear to match the version set in the project ("PKG_version", "PKG_buildNumber").
Any chance this is documented or already fixed in LabVIEW 2020?
Message 1 of 1
(1,765 Views)
