Application Builder 6 on Win2000
I build an application with the AB 6i on Win2000 and want the installer to run a executable after installation. A simple *.bat file making a new directory, but it does not work. It did work fine with AB 5.1 (also on Win2000). What do I do wrong?
Arne May
(2,840 Views)
You can click on "Advanced" button in AB and type you batch file name in executable textbox. You must have the batch file in the "data" folder on the target machine. Install the exe normally and run it. it will call the batch file from data folder.
Good Luck
A Rafiq
NAtional Instruments
(2,840 Views)
Yes I do that, and the installer also copy the batch file to the target folder, but it does not run the batch file.
Regards Arne May
(2,840 Views)
