Appending Square Waves
Hello I am trying to create a VI that will generate a waveform from two 1D arrays, one for the amplitude of a section of the waveform and another for the duration of that section. For example if I were to put in [1,2,3] into the amplitude array and [2,5,10] into the duration array I would receive a graph that had an amplitude of 1 for 2 seconds, then amplitude 2 for 5 seconds, then aplitude 3 for 10 seconds. I am using the Append Waveform function to do this.
I have a VI that will generate the amplitudes correctly, but the delays do not work, each amplitude is only true for one second a piece, no matter what i put into the delay array. Does anyone have any suggestions on how to force the amplitudes to be active for a given amount of time?
I have attached a picture of my code so far.
Thank you
(2,909 Views)
For the build square wave, you need to alter the Sampling Information.  It is a cluster with Fs (sampling frequency) and #s (number of samples).  You need to calculate how many samples to do given your desired sample rate.
(2,904 Views)
Accepted by topic author Nexxus
I think this will do what you are looking for.
(2,898 Views)
Thanks a lot that looks great.
(2,894 Views)
