Append a Table Control
Hello All,
I am trying to capture three values of a DC motor at different voltages using Labview 2020. Say 2, 4 and 6 volts record attribute A, B and C. Then the data to be presented on the first row of a table control. The first cell displaying the sample number entered in a string control followed by the data. See attached example .png. There are multiple motors to collect data for. I would like the data to be appended to the table on the subsequent rows. This is part of a much larger program. So I built a separate vi to work with. I am using random number generators to simulate the data. This vi does collect the data and present it the way I want. Adding the subsequent lines is the problem. I know I need to add a second dimension to the array using a shift register..........This is where I am stuck. Any suggestions would be greatly appreciated.
Thank you.
(1,622 Views)
I looked at your VI and tried to replicate similar functionality with your code with some changes in it.
You could try to initialize a 2-D array and linked it to the shift register. The random numbers generated in the For Loop are then inserted the 2-D array using the "Insert Into Array" function, which later then passed into the shift register. I have also attached the code in the image file for your reference.
Cheers.
(1,534 Views)
