Append FP Image to Report
if I use Append Front Panel Image to report.vi in a standard report, the vi name is attached under the image.
How can I avoid it?
Thanks & Regards
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
(2,745 Views)
You get the VI name IF you don't wire a description or if the description is an empty string. Wire e.g. an single space character to the "description" input of "Append Front panel image to report".
See if this helps! 🙂
(2,739 Views)
Thanks a lot!
I didn't pay attention to the T/F Select in "Append Front Panel Image to Report (path).vi" block diagram.
Vix
Using LV from 7
(2,725 Views)
