Appearance of while loop
hello,
just curious,
How to get the while loop that looks like the below [IMAGE]
Source : Document
Abhilash S Nair
Research Assistant @ Photonic Devices and Systems lab
[ LabView professional Development System - Version 11.0 - 32-bit ]
LabView Gear:
1. NI PXI-7951R & NI 5761
2. The Imaging Source USB 3.0 monochrome camera with trigger : DMK 23UM021
OPERATING SYSTEM - [ MS windows 7 Home Premium 64-bit SP-1 ]
CPU - [Intel Core i7-2600 CPU @ 3.40Ghz ]
MEMORY - [ 16.0 GB RAM ]
GPU - [ NVIDIA GeForce GT 530 ]
(2,769 Views)
Not sure about LabVIEW 2011 (I just did a re-install and had to remove 2011), but in LabVIEW 2012, this is called a Subdiagram Label.  If you right-click the While loop and look at Visible Items (in 2012), Subdiagram Label will appear.  To make it look like your figure, you need to change the background and text colors, which you can do with tools on the Tools Palette (on Block Diagram, click View, then Tools Palette).
BS
(2,763 Views)
Don't forget to use the eye dropper to match the loop color Smiley Wink
(2,755 Views)
In LabVIEW 2011 drop down a free label and match colours to your loop and then drag/cursor it into place. I would only recommend doing this once you have the size and position of the loop finalised as it doesn't move with the loop as it does in 2012 as a subdiagram label.
Mike
(2,719 Views)
