App Builder produces "Not Executable" error with Strictly Typed VI Refs
There is a very frustrating problem with the app builder in LV 8.0.1.  Certain VIs compile and run fine in labview, but the app builder refuses to make them into applications.
The error message is very long and ends with something like "The VI is not executable".  Standard advice for this problem is to force LV to recompile everything you're building by either mass compiling or ctrl-shift clicking the run arrow, but this hasn't worked for me in two separate cases (completely different projects).
It seems that this problem is caused by wiring a strictly typed VI reference to an invoke node with the FP.open method selected.  In both cases I resolved the issue by changing the Static VI Reference to be weakly typed (right-click the static vi reference and make sure "Strictly Typed VI Reference" is unchecked). After that, the project build successfully.
This is very hard for a user to track down for several reasons:
 - The error message in the application builder does not give any indication as to what the real problem is
 - The app builder reports that the top-level VI is broken, even when the strictly typed reference and invoke node may occur in a sub VI
 - Nothing (that I can find at least) in the documentation suggests that strictly typed references won't work with the Open.FP method.  There is a page that says "some of the properties and methods do not work when you configure this function to output a strictly typed VI reference," but no indication is given of which methods fail
Note that in one case I was also able to make the project build by deleting an instance of "IMAQ Create.vi" from the top-level VI.  I  have no explanation for this.
Hopefully this post will save some other users the trouble of tracking this down and maybe even get NI to correct the issue for future versions.
Adam Brewster
(2,961 Views)
Hello Adam,
Thank you for sharing your experience and insight.  Your post was well thought-out and offered a good description of the problem as well as some possible workarounds.  I believe that the issue has been filed and is under investigation (3TU8T8V9).  Feel free to post back after the next LabVIEW release and inquire as to its status.
Thanks again,
Travis M
LabVIEW R&D
(2,940 Views)
lo stesso problema mi è capitato con application builder di labview 2011,  nel VI avevo collegato uno Static VI Reference con l'opzione Strictly typed VI reference ad un property node fp open.  Il problema sparisce togliendo il chek a Strictly typed VI reference
inoltre volevo segnalare che nel context help di Static VI Reference c'è scritto di fare doppio clik per far comparire la dialog box in cui selezionare il VI, invece bisogna premere tasto destro e selezionare "browse for path"
(2,594 Views)
