Anyway to display only vertical scroll bar
I need a vertical scroll bar to be displayed not both on front panel during execution. My application contains more than 200 parameters to be read & display it on the screen. I scroll the front panel programatically, so that operator need not to scroll the front panel every time. Whenever operator / technician need to look out the previous reading during execution, a vertical scroll bar must be required. I have attached a VI for sample. My application running on Windows 98, NT & 2000.
(2,908 Views)
hi, I am not sure about that but have your tried using Tab Control for all your parameters?
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
(2,908 Views)
Why do you not use a floating scroll bar. The attached example shows how to do the coding but needs to be made pretty.
Jeremy
(2,908 Views)
Im trying to do something very similar to this. It is a scroll bar that control the same vi where it is?. The problem is that when the vi is running and I use the scroll bar it also moves and is a mess. I need to have it in a fixed position within the window, how can I do that?
(2,908 Views)
