Anybody can help me regarding ring control?
Hai...
I am using a ring control in my application.
And i have stuffed data into that from a 1D arry.
I have initialised its ring text to the first element of the array.
Now the problem is,if the array is having 10 elements ,the ring will contain 10 elements but one of the elements
is appearing twice there by missing one actual data.
If the ring text is "?sample" sample will be appearing as ring text andas last element of the ring.
and one of them is having a check mark.
I havent faced such a problem before and i am not much experienced in labview.
Then one more thing.When i click the ring control,it pops down.How do i display the elements as popped up?
How to include scroll bars to ring?
Thanks...
(2,531 Views)
user_1,
please do not post the same question twice....
It would help a lot if you could attach your test that everybody can look into the issue you are running into. To be honest, i was not able to reproduce the issue...
regards,
Norbert B.
Norbert
Expert: Geometry
(2,525 Views)
