Any way to capture keystrokes from a usb keyboard on an RT box?
I have a motor connected to an RT box through the RS232 port and I want to be able to step it with a USB keyboard attached to it. Is this possible?
CLED (2016)
(3,531 Views)
Hi InfiniteN…,
i think it's possible if you have a keyborad driver for your RT box. If your RT box has a n Ethernet connection to another pc, then you can send TCP/IP packages and control your motor from there.
Hope it helps.
Mike
(3,516 Views)
Yes, the latter option (TCP/IP) would certainly work but that would involve purchasing another computer.
Please explain the RT driver option.
I was also considering a USB RAW through visa possibility.
CLED (2016)
(3,508 Views)
Thread bump. Should I assume it is not possible to capture keystrokes from a USB keyboard directly attached to the RT box?
CLED (2016)
(3,478 Views)
Maybe they are quite hard to find but a serial keyboard would be much easier
But I don't know the USB support in Visa for RT, maybe you can get the raw USB stream and read it from there.
Ton
Message Edited by TonP on 12-19-2008 07:29 PM
My LabVIEW Ideas
(3,474 Views)
I need the serial port for sending motor comands
CLED (2016)
(3,462 Views)
Hi InfiniteNothing,
Right now, the USB port can only be used for storage.  Unless your RT box has an additional serial port, you will be unable to use the keyboard.  Again, developing a host VI to control the motor is your best bet even though that requires a second pc.  For applications such as yours, filing product suggestions here (http://digital.ni.com/applications/psc.nsf/default?OpenForm) will ensure that future versions can support these features.
(3,417 Views)
