Any plot in LV can display point density by color like this
I saw a plot function of activeX as attached screen.
It can display the data point to point and show the desity of the point by color. Also it has a legend at the right side.
Is there any same function in LV? Thanks.
(3,461 Views)
Attachment?
(3,460 Views)
Sorry, missing, attached again.
(3,448 Views)
You can use an intensity graph. Here's an example (form this thread) Make sure to display the z-scale.
(3,423 Views)
Looks cool, just one little question, can I the line change to point?
Can I put a color legend at the right side? It is possible to put more color gradient.
Thanks.
(3,411 Views)
You can do whatever you want with a little bit of coding. For full flexibility I would recommend a picture indicator, though. 😉
At the moment, it uses an intensity graph. As I said, you can show the z-scale and define any gradient you want.
Message Edited by altenbach on 08-11-2009 06:49 AM
(3,397 Views)
