Any idea how to replace power of X function in FPGA?
Hi all,
Any idea how I need to use power of X function in FPGA. It is not available there, any idea how it works in FPGA?
(3,408 Views)
Hi WatFin,
use a loop to calculate (positive integer) powers of a value!
For other values you can use the high-throughput Exponential function! Simple math: x^y = e^(y*ln(x))…
(3,405 Views)
Thankyou,
I was thinking if there is ready function. I will do in that way.
(3,395 Views)
For negative integer powers, compute 1/(x^|n|), i.e. the reciprocal of the positive integer power.  If n is small (say < 8), a For loop to do n multiplications is simple and quick.  If n is large, you can express it as a binary integer and work with squares of x (i.e. n = 10 = 1010b, compute x^2 and ((x^2)^2)^2 and multiply them together.  Note that you should probably do some timing tests to verify that the squaring method (a) works and (b) "makes a difference".
(3,352 Views)
