Any Ethernet/IP examples or tutorials?
Hi!
So, for the first time, i have to work with the ethernet/ip protocol.
I would like to know if there is any examples or tutorials about the protocol and how to program the communication read/write.
I've check on the internet and read the documentation and i know a bit how to do it with the address and everything but nothing more.
One thing i don't know what it is, is the "number of elements" input. Is it only the number of element in my array for example? So, if my array contain 4 values and i put 3 elements in the inputs of the "Tag Read", i will only read the first 3 values?
Another thing is that i dont have access to a PLC for now. Is there a way to simulate one? So i can know my path is good, know if i send/receive the data i want and test more things before having the PLC with me?
Thank you!
    - Dave
Message 1 of 8
(7,761 Views)
Look under Help --> Find Examples and then search for TCP/IP.  There are a few (hopefully) helpful examples.
Bill
CLD
(Mid-Level minion.)
Message 2 of 8
(7,736 Views)
LabVIEW gives you UDP and TCP, no access to lower levels of the protocol (ethernet, or IP).
It is not clear what functions you are looking at. Typical TCP and UDP functions don't have any inputs resembling your description. All data needs to be flattened to a string for transport. Are you using a toolkit? Can you show us some code? Is this classic LabVIEW or NXG?
Message 3 of 8
(7,725 Views)
Bill, the OP is talking about EtherNet/IP, which is an industrial protocol.  NI sells a driver for it.
It has been too long since I messed around with that driver and I no longer have access to it.  I could potentially dig around to see if I have a copy of an old project, but I am just going to back away from this and hope somebody with better knowledge comes in.
Message 4 of 8
(7,706 Views)
I can't believe I misread that.  To the OP - sorry about that!
Bill
CLD
(Mid-Level minion.)
Message 5 of 8
(7,693 Views)
Hi!
I have played a bit with Labview and the driver to see if i can do something and i think i have something! But it could be nice to see an example of a working project so i could double check what i did, if yours arent too far, it would be appreciated!
@billko No problems! Can happen haha
Message 6 of 8
(7,661 Views)
Obviously, you could have avoided a lot of confusion by using the correct lettercase (EtherNet/IP vs. ethernet/ip) and even put it in quotes or include a link.
... especially since they had the horrible idea to reuse well defined generic terms for a very specific protocol. What were they thinking? 😮
Message 7 of 8
(7,645 Views)
Have you been able to provide find any?
Message 8 of 8
(2,746 Views)
