AnotherVIEW to LVOOP
Salut.
Here is an exploration of an alternative/complimentary direction to LVOOP that can be chosen to enhance/accelerate the code creation and manageability in LabVIEW. I willingly posted this on Info-LabVIEW, LAVA and NI's forums, in order to reach the largest base of opinions possible. I propose that everyone who is a member of LAVA post's there, to try and limit the redundancy. I did not want to post it only on LAVA and go to Info-LabVIEW and NI's forum to say "Go see this on LAVA" because not everyone wants to become a member of LAVA and I would like to get their opinions to.
I plan on gathering all the information and publishing it on an FTP site.
MS Word version
ftp://all:Password1@ftp.cephom.ca/AnotherVIEW.doc
Browser version
ftp://all:Password1@ftp.cephom.ca/AnotherVIEW.htm
(3,239 Views)
Try posting the link again.  A smiley face is appearing in the link which messes up the browser.  Maybe just type it out or turn off the Edit As HTML feature.
- tbob
Inventor of the WORM Global
(3,190 Views)
Here's a link to the LAVA thread, where you click the links.
The problem is that the NI board always renders the ": p" as :P.
___________________
Try to take over the world!
(3,193 Views)
(3,170 Views)
Made an update to the document. Between ******* below
5.3.3.3     AnotherVIEW Implementation
All data would be public by default and it could be possible to restrict access to a certain elements in the Hierarchy by right-clicking on it and selecting restrict access to those VI’s and consequently the unbundle and bundle function would only allow this data to be accessed when used in those VI’s. More complex behavior could be added directly in the configuration of the “eTD” used in conjunction with “eBundle” and “eUnbundle”.
*******The data that would need to be accessed by parallel process just needs to be “encapsulated” in a functional global variable. A software could consist of basically 2 main hierarchical clusters, 1 for the dataflow in a wire, and the other in a global for parallel processes that need access to it if required.*******
Also tiny links for those who were not able to use the previous hyperlinks
MS-Word
http://tinyurl.com/ys7hof
HTML
http://tinyurl.com/2698ob
(3,134 Views)
