Announcing LabVIEW 2024 Q3!
LabVIEW 2024 Q3 was released on July 16th and is available for download!
We’re excited to announce the release of LabVIEW 2024 Q3, which comes with exciting new features designed to improve collaboration.
  • Saving All VIs in a Project for a Previous Version of LabVIEW (Configure Project Save Version) – take advantage of the latest editor features while maintaining your Project’s LabVIEW version
  • Improvements to Compare VIs – focus on reviewing code changes with new enhancements that make the process more efficient.
  • Preview of .NET 8.0 Support – introducing limited support for loading and running .NET Core (8.0) assemblies on Windows.
For more information, view the Manual or read below:
Preview Feature: .NET Core (8.0) Support in LabVIEW
LabVIEW 2024 Q3 provides limited support for loading and running .NET Core (8.0) assemblies on Windows, including:
  • Enabling constructor nodes, property nodes, and invoke nodes to work with .NET Core (8.0)
  • Supporting the following four data types:
    • int
    • string
    • bool
    • char
To enable .NET Core (8.0) support in LabVIEW 2024 Q3, navigate to Tools » Options, select the Preview Features category, and select the Enable .NET Core (8.0) Support checkbox.
You can configure LabVIEW to automatically save all VIs in a project for a previous version of LabVIEW. If a VI contains features not compatible with the designated version, LabVIEW displays a warning and saves the VI for the earliest version that supports all features in that VI.
Improvements to Comparing Vis
  • You can click an item in the differences list or details list to highlight it.
  • You can use the left and right arrow keys to move between the differences list and the details list, and you can use the up and down arrow keys to move through the differences and details.
  • In the Differences dialog box, a difference appears italicized if it involves only front panel position/size changes or block diagram cosmetic changes.
  • The diagrams can automatically scale to fit an entire difference.
  • You can swap the positions of the compared VIs by selecting More commands » Swap VI Positions in the Differences dialog box.
You can download LabVIEW, here, today!
Update 8/14: LabVIEW 2024 Q3 Patch 1 is available on ni.com or NI Package Manager.
Update 10/16: LabVIEW 2024 Q3 Patch 2 is available on ni.com or NI Package Manager.
You can find more information on the LabVIEW 2024 Q3 Bug Fixes page.
And for assistance with installing patches, learn more in this KnowledgeBase article: Identifying and Installing Patches.
Message 1 of 1
(29,218 Views)
