Animation period
Hi there.
I have a question, hopefully you can give me some suggestions.
I have written a Labview program, just to record the measurements for the Current with respective to time and compared it to the software program (Nanonis). I have chosen that each data would be taken at 20ms. However, when I compared the graph obtained from my Labview program to the software program (company), the result don't seems to be matching. Smiley Sad
Can you give me some suggestions on improving the program?  Or if I had made any mistake somewhere, can you kindly point it out to me?
I have attached the PDF (showing the graph and my program) to this message.
Thank you in advance.
(2,601 Views)
Hi
I think the problem comes from in the long term chart there is an integration of the signal during the delay time set as "0.5" on your screenshot. To find the same graph than in your labview one, you have not to long term chart but history channel I guess.
JeanGreen
(2,487 Views)
