Android copying files via Bluetooth
Hi everybody,
I want to copy files between android smart phone and PC using bluetooth communication.
Android files are stored on flash card. PC is local with OS Win7.
Please can you help me to solve this problem? I will be grateful for every idea.
Thanks.
(3,326 Views)
this is a forum for LabVIEW questions, so I am assuming you are trying to develop a bluetooth application through LabVIEW. The links below talk more about using bluetooth in LabVIEW.
Developing Bluetooth Applications in LabVIEW
How do I make a Bluetooth device work with LabVIEW?
If you are just trying to transfer files between an Android device and Windows, I would suggest looking at an android specific forum.
Thanks!
Gabriel M.
Product Marketing Engineer - Academic Courseware
(3,248 Views)
Should be simple enough to pair your tablet with the PC and initiate a BT file transfer.
Don't even need LabView for that.
=== Engineer Ambiguously ===
(3,239 Views)
Thank you for your answer. I solved this problem created FTP server on android device. That is so easy to use files system on android.
(3,144 Views)
