Analyzing a .TDMS file
The Excel TDM add-in is installed by default with LabVIEW but it's also available as a free download to make exchanging data between engineers a little easier.
http://zone.ni.com/devzone/cda/epd/p/id/2944
Message 11 of 17
(2,319 Views)
@sam.ferguson wrote:
So, bear with me Dennis, I use the Read TDMS.vi to open up the file and then from there read the data into arrays? Is that what you are suggesting?
Try this code.
Charles Chickering
Architecture is art with rules.
...and the rules are more like guidelines
Message 12 of 17
(2,291 Views)
Thanks Charles, I'll give that a shot.  Also YongqingYe I used the .vi from this post to convert the .tdms programmatically: http://forums.ni.com/t5/LabVIEW/Convert-Import-TDMS-to-Excel/td-p/1088746
Message 13 of 17
(2,267 Views)
Charles, that .vi works great! Any idea how I can turn this into a batch process for several files?
Message 14 of 17
(2,258 Views)
Accepted by topic author sam.ferguson
Make the VI that I sent you a SubVI (connect the path, min, max and mean to the connector pane). Write code to return an array of files, put the SubVI in a for loop and run it. See attached for getting started.
Charles Chickering
Message 15 of 17
(2,251 Views)
Wow, very helpful.  Thanks again.
Message 16 of 17
(2,248 Views)
I see. Thank you, sam.ferguson.
In LV 2013, there's a new feature to write Excel .xlsx files by using Write to Measurement File Express VI, just for your information.
Message 17 of 17
(2,224 Views)
