09-30-2008 09:49 AM - edited 09-30-2008 09:52 AM
Is there a way to retrieve the Descriptions for each of the VI Analyzer Test Names?
I've searched around in the llbs within the vi.lib\addons\analyzer folder but couldn't find a function to do this.
Example: Arrays and Strings in Loops has the description:
Checks loops to see if they contain Build Array or Concatenate Strings functions. Avoid using these functions in loops because each call to them requires a dynamic resizing of the array or string, which can affect memory and processor time. This test does not check Timed Loops.
Solved! Go to Solution.
10-01-2008 06:06 PM
Phillip,
There are currently not any VIs that I know of that has this functionality. The best bet would be to use the Help to get the descriptions. If you wanted this in a VI, you would probably want to to create an array constant of all the descriptions (manually) and then index them based on the Test Names.
This is definitely a good product suggestion though!
10-06-2008 07:43 AM - edited 10-06-2008 07:47 AM
I looked around a bit more, and discovered that the info I wanted is contained in the VI Description of a VI that matches the name of test test plus "Config.VI". I used VI Server to open the LVLIB that contains these "Config" vis and used "Get All Descendents". I extracted the descriptions that I wanted using VI Server.
See attached VI (LV 8.6)
