Analog input data for NI USB 6001
Hi Gerd,
I am attaching the photos my readings of both sensors.
1. Absolute pressure its reading fine and also showing us the output. The reading is 1.06bar and I am reducing the pressure to 0.4bar.
2. Relative pressure is reading but its fluctuating and not showing the same readings as Absolute pressure . Here sensor Kistler 701A is connected to a charge amplifier kistler type 5041.
My question is that when i am reading pressure inside the chamber for  Absolute pressure graph its showing the right value but the other i.e relative pressure sensor its not showing same value I dont understand why. No when i reset my charge amplifier I should be able to start at 0.4 bar for example because the pressure inside chamber is 0.4. You already have my program can you please help me its important.
Message 11 of 15
(973 Views)
Hi Abhishek,
Can you verify the readings of this AI channel using a simple DMM?
Do you get the same values using the DMM - or do you get different readings?
In image Analog3 it seems to show some noise for your "pressure 2 (relative)" sensor. (Or some aliased low frequency noise like power supply 50/60 Hz noise…)
Please verify your readings using a some other DAQ hardware like a simple DMM!
Message 12 of 15
(964 Views)
Hi
I only have two NI USB 6001 devices because I am doing a project and the university provided only this. I don't have any other hardware.
Sorry is there any other solution for this problem?
Message 13 of 15
(957 Views)
Hi Abhishek,
there is no simple DMM in the lab/at the department/in the whole university available for a short cross-check of your measurements?
Which kind of university did you choose?
Message 14 of 15
(947 Views)
hello,
I am sorry it was my mistake I thought of DMM as USB DAQ. I checked the voltage and my readings were also right in order to see the graph I just made the voltage value from data converted into millivolts as I was measuring less than 0bar relative. I got to know that my pressure sensor is calibrated in such a way that for 1bar absolute it's showing as 0 bar. So due to this reason, I couldn't able to see the rise in my other graph as it was showing values in volts.
But anyway thank you very for your help.
Message 15 of 15
(928 Views)
