Analog Output Control via PCI 6024E Multifunction
I need to output an analog signal(-5-5V) on an analog output channel, I need to be able to change the output voltage by a simple control on the front panel, the voltage will be continuously outputted for up to 15mins max probably. The voltage will only need to be changed now and then and then stay at that for a while untill the next voltage change. What's the best way to do this, all the examples I've found have used an internal clock etc which cannot be done as they are in use. There must be a simple way to do this?
(3,013 Views)
Yes, this would be quite simple. Have a look at the attached code and see if this is the type of example you are looking for!
(2,994 Views)
Thanks for the file but I am only running version 7.0 and so cannot open it, which is highyly annoying. Don't suppose you've got it in version 7.0?!
Cheers
(2,992 Views)
Hi Allstar,
Try this one.
(2,978 Views)
Thanks, it works. Cheers!
(2,953 Views)
