Analog Input PCIe6341 + 2090A Same reading on 2 different channels
Hello all!
I'm not sure this is the right forum for this... But still, I hope to find an answer.
First time I'm using PCIe card 6341 with 2090A BNC.
I've connected 2 channels to DC voltage source and defined to read 3 channels in LabVIEW, on the 3rd channel i'm expecting to get some noise (near ~0Vdc).
For example, channel 0 connected to 3Vdc and channel 1 to 1.5Vdc.
But, for some reason channels 1,2 show the same input value (front pannel screenshot attached):
Every input you guys may have, will be very much appreciated.
(1,339 Views)
Accepted by topic author IG.B
Hi IGB,
Your expectations are wrong… 😄
You are using a MUX devices, using just one ADC for all channels. What you are seeing is explained as "ghosting"
(1,290 Views)
