Analog ECG signal to LabVIEW
Hello I am trying to get my analog ECG pulse into LabVIEW from my SC-2075 breadboard. I am having trouble getting the signal into LabVIEW, and I am getting incorrect waveform pulse. I have checked my circuit which consist of an instrumentation amplifier, a 60 Hz notch filter, and a Low Pass Filter. LabVIEW is being very inconsistent with getting the pulse to look like an actual heart rate like its supposed to, and I would like to know why it does not always work. Attached is my LabVIEW circuit, however it can not accurately read my heart. I also do not have access to the Biomedical Toolkit or any Advanced Signal Processing Toolkits.
(2,687 Views)
Does you DAQ Assistant setup make sense?
To me it doesn't.  you are reading N sample mode, 100 samples at 1000  Hz rate.  That means you are getting 1/10 second of data.  Then the code stops collecting, does its calculations, then the loop iterates again collecting another 1/10 of a second having missed all the data after the last capture because it is in N sample mode rather than continuous sample mode.
Even if you fixed that, how do you expect to see enough heartbeats in a 1/10 of second?  Since heart rates are about 60-120+ beats per minute, it is going to take at least a couple seconds before you see a few heart beats to be able to measure the time difference between them!   Try setting 3000 samples at 1000 Hz rate, continuous mode.
(2,664 Views)
Ah, my two Pet Peeves, the Dreaded DAQ Assistant and its evil twin, the Dynamic Data Wire!  I've pasted this link into the Forum so many times that I'll only say "Do a Web Search" for the phrase "Learn 10 Functions in NI-DAQmx and Solve 80 Percent ...".  Read it, learn how to banish the DDA (Dreaded DAQ Assistant) and vow to never again use the Dynamic Data Wire!  [Minor drawback -- you'll need to learn/use a little more LabVIEW] [Major advantage -- you'll need to learn/use a little more LabVIEW].
(2,648 Views)
