An exception occured within the external code called by a Call Library Node.... was stopped at node "" at a call to "IMAQ RejectBorder"
I get occasionnaly this message when running an executable which has been installed from the same machine:
LabVIEW: An exception occurred within the external code called by a Call Library Node. This might have corrupted LabVIEW's memory. Save any work to a new location and restart LabVIEW. VI "1629-00_200-Main.vi" was stopped at node "" of subVI "IMAQ RejectBorder"
It is really anoying because the executable can run without any poblems for many hours and then the message comes and can crash the application
Any advice?
Version:
LV 8.2
IMAQ Vision 8.2
Rodolphe Naoux
(2,876 Views)
Hi Rodolphe,
it seems that there is a memory leak. Have you close every reference? Has the VI  the same behavoiur as your application?
Rebecca Fox
(2,862 Views)
