06-30-2008 01:01 PM
07-01-2008 01:11 AM
07-01-2008 08:49 AM
07-01-2008
01:31 PM
- last edited on
06-03-2025
01:22 PM
by
Content Cleaner
It it very possible that you have developed your application (.exe) with one version of the NI-DAQ driver on the 98 machine and have loaded a different version of NI-DAQ on to the XP machine. This would explain both error 21 and 10243. There are only a couple of versions of the NI-DAQ driver that support both 98 and XP. Thus, it is very likely that you could have developed on the 98 machine with a version of NI-DAQ that does not support XP. Please check that you are developing on 98 with either of these versions of NI-DAQ 6.9.0, 6.9.3 with patch 6.9.3f5, 7.0, or 7.1. I would recommend using 7.1, since it is the most recent of the Traditional NI-DAQ drivers that support both OS. If you find that your .exe was developed with a version older than 6.9.0 you might need to upgrade the driver on the developement machine.
Please also make sure that you are using the same version of LabVIEW and DAQ driver on both the developement and target machine.
