Amigo robots - error 310153
Hi. I run the example MobileRobots interface example, where I put the host: 192.168.1.12 and the port 8101 for Amigo robots and I still get the error 310153 - unable to connect to sever. Do you have any idea why can't I connect to the robot?
Alina.
(2,627 Views)
Can the problem come from the fact that the host is an IP and not a name?
(2,622 Views)
Have you tried pinging the device? Have you made sure the ports aren't being blocked by your firewall or your router? I don't think the IP vs name should be a problem, but it's worth trying to change to the computer name to rule it out.
(2,615 Views)
