Alternatives to calling LabVIEW created DLLs from LabVIEW?
I would like to create a compiled LabVIEW application (Exe) that is modular in the sense that it that can load other external, LV-compiled modules at runtime. What is the best option? I see that I can compile a DLL with from LV code, but get the sense that this is usually when you wan to call LV created code in another programming language. Using the Call Library Function node seems a cumbersome way to call LV compiled code. I know I can write a LV Exe to dynamically load a .VI file at runtime (provided the VI's compiled code has not been separated). This seems like a better approach but don't really want to distribute the "source" code. Packed Project Libraries seems overkill and geared towards code sharing. Of course I can compile other Exes an load them but then have to deal with inter-process communications.
Message 1 of 10
(2,532 Views)
Hi Edu,
So you don't want to share source code, but you think lvlibp is "overkill"?
They just provide a clean way to distribute compiled VI libraries without their source code…
Message 2 of 10
(2,527 Views)
I agree with GerdW. You're over-complicating this.
A packed project library is exactly what you're looking for. In your final released code it's a single file, it doesn't contain your source code with it because it's compiled, and it's easily callable from your main LabVIEW application.
Message 3 of 10
(2,512 Views)
Third vote for packed project libraries. They are great for implementing plugins.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 4 of 10
(2,503 Views)
Thanks for the quick replies. An LVLIB seems overkill from the perspective: if I want to create an LVLIB for a single wouldn't I have to create a separate project just for that one VI? When I try to create a Packed Project Library it tells me I need to include a Top Level Library. So I need to create a library before I can create a library?
Message 5 of 10
(2,499 Views)
Packed project library is the compiled version of a LV Library. So yes, you need something to compile before you can compile it.
Generally a packed project library will have multiple VIs in it, not just a single. What you're suggesting would be the equivalent of creating a .DLL with a single call. Yes it would be doable, but it would be cumbersome in either case.
Message 6 of 10
(2,496 Views)
Another vote for PPL, it is the defacto, proven, reliable and scalable way to go for plugins
Santhosh
Soliton Technologies
Message 7 of 10
(2,479 Views)
-Santhosh
Semiconductor Validation & Production Test
NI CLD, CTD
LabVIEW + TestStand + TestStand Semiconductor Module (2013 - 2020)
NI STS for Mixed signal and RF
Things Not To Do
  • Do not have huge signatures. They waste space on the forum and can clutter the conversation. Signatures are okay, but large ones are discouraged.
Message 8 of 10
(2,379 Views)
@santo_13 wrote:
From the community guidelines
Things Not To Do
Message 9 of 10
(2,393 Views)
Things Not To Do
Message 10 of 10
(2,395 Views)
