Alternative strings in Match Pattern function
I want to extract from a string the string that lays after two possible patterns. They are the string "CLOCK" and its lower case string "clock". I use the Match Pattern function enclosing the two alternatives between brackets (as shown in the Function & VI Reference Manual, chapter 6). But it doesn't work. Is that because I use the 4.0 version? Otherwise, how could I do this?
(3,309 Views)
You have to use the "regular expression" input string as
[Cc][Ll][Oo][Cc][Kk]
and in "after substring" you will get the result of extracting.
For example
CLOCK900 -> 900
clock900 -> 900
ClOcK900 -> 900
cLoCk900 -> 900
and so on.
I've checked it with my LV6 and it works fine.
Good luck.
Oleg Chutko.
(3,309 Views)
I've used that same expression on my example. I thought it would work, but it doesn't.
I think it may be a matter of the version I use (4.0) is much old for this.
How could I do something that works like that?
Maybe using the function twice?
(3,309 Views)
"AndresMenacho" wrote in message
news:506500000005000000345A0000-1011517314000@exchange.ni.com...
> Thanks,
> but it doesn't.
> this.
Convert the string to lower case and then search for the pattern? Upper and
lower case conversions have been there for a long time.
Craig Graham
Physicist/Labview Programmer
Lancaster University, UK
(3,309 Views)
Yes,
that is what I did instead of the first option reported.
Also I realized that I had written incorrectly the expression "[Cc][Ll][...". So that option works fine too.
Thanks to the two of you, after all.
(3,309 Views)
