Alternate for nested case structure
I need to avoid / find alternate for nested case structure. is there any good solution for the nested case structure inside. I have attached sample nested case structure VI. Can some one help out with better solution.
Message 1 of 9
(8,934 Views)
Accepted by topic author Technical_details
Hi details,
Why do you need all those local variables?
Just use wires:
Use values of 0/1 for "DUT Sel" too. (Infact all 3 parameters use just two items: why not use boolean inputs then?)
When using item value ranges starting with zero you could use those input parameters to index an array of "action items" and simply call a state of a state machine using this "action item":
(I would just use a QMH approach with a state machine handling the messages…)
Message 2 of 9
(8,928 Views)
Hi Gred,
I have use Ring / Enum instead of Boolean because i may add few more parameter in the drop down in future if required.
secondly, when i tried to index the way you did it happened like this
Message 3 of 9
(8,920 Views)
Hi Dteails,
Well, you did not wire l"the way I did" - you did something different!
Why did you increase/resize the IndexArray node to index 3 elements?
Why did you only wire the page input? I wired all 3 index inputs to index a single element from a 3D array…
Then use consecutive ring item values starting from zero (like in enums) for easier array indexing…
Message 4 of 9
(8,914 Views)
Hi Gred,
I have tried the way advised but i couldnt figure it out exactly how it works and am not getting the correct sate. attached the VI
Message 5 of 9
(8,869 Views)
Hi details,
several problems:
- in your array constant you only created the first page: as soon as you switch "Man/Auto" to "Auto" you try to index non-existing elements
- in your array constant you created a page containing 8×3 elements, yet "DUT" and "Parameter" only provide two different items each: it would be sufficient to create a page of 2×2 elements…
- minor problem: there is no wait in your loop…
Message 6 of 9
(8,866 Views)
Hi Gred,
I have understood the issue and the concept. as you said 2x2 matrix is sufficient for this case and the page to be filled with desired value. Thanks.
Message 7 of 9
(8,862 Views)
You have stated that we can use Queued Message handler for this case. how it makes difference in using QMH and how effective it will be.
Message 8 of 9
(8,858 Views)
Hi details,
You could separate UI handling (using efficient event structure) from processing your data (in your consumer loop). You could have your data processing sorted in a clean statemachine.
(The "effectiveness" depends on your programming :D)
Message 9 of 9
(8,853 Views)
