Also Help In pulse generation
Dear Sir,
Thank you very much for your concern and help.
I try a lot to apply the suggestion solution and I search for the example and I was able to generate some pulses but not the needed one (6 pulses each pluse duration is 0,15 m sec with cycle duration is 7,5 m sec, and then 2 sec wait and a new 6 pluses train, etc).
In this message I attach an image for the exact shape of the pulses I need to generate, so please if anyone can help me to generate this continuous pulses train by any kind of help, please send me, because i try a lot without any benefit.
Thank you again very much.
(2,897 Views)
What hardware are you using, this can be done with a set of counter/timer but you will have to adjust the voltage after generation (since this will produce 0-5V TTL signals not 1.5V)  you can also use AO using an arbitrary waveform output (I have not tried this).  Please post the intended hardware.
Paul
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(2,880 Views)
