Allocating memory
I am trying to allocate a block of memory to act
as the memory address to output data from a frame
grabber I am trying to interface. Currently I am
calling GlobalAlloc in Kernel32.dll and looking
at the returned address using the OutPort vi.
I've set the flags in the Global Alloc to give me
a fixed memory address and fill it with zeros.
However when I look at the address with outport
then it hasn't been reset to 0. Any suggestions
as to what could be the problem or alternative
ideas for allocating memory would be welcome.
David
Sent via Deja.com http://www.deja.com/
Before you buy.
(3,149 Views)
The outport function will address IO port address space and not memory
address space.
In order for LabVIEW to access the type of memory you are refering to, you
must use a DLL call.
Stu
wrote in message
news:90livc$86f$1@nnrp1.deja.com...
> i
> David
> Before you buy.
Stu
(3,149 Views)
