Allocating Events
I am having trouble getting the Mouse Up Event to work with an Active
X tree object.
However the Mouse-Down event works to an extent but you have to
select, then click to open.
Any thoughts?
cheers.
(2,813 Views)
Mouse down outside of the tree control, then mouse up inside of the contol. This should cause the mouse up event to work. I tried mouse down with other activeX controls and there were no problems. It is as if the tree control redirects the mouse event.
Jeremy
(2,813 Views)
