03-15-2002 05:37 PM
03-18-2002
10:31 AM
- last edited on
05-15-2025
04:06 PM
by
Content Cleaner
Nelson,
The IA OPC Server CD does not contain software that supports the AB SLC5/05 PLC. However, you should be able to access data directly from the RSLinx OEM OPC Server.
To verify functionality of the RSLinx OEM OPC Server, you can download a generic OPC client called Server Explorer.
For more information about addressing allen bradley plc's, please see the document titled "Notes on Allen Bradley PLC Addressing"
These documents should give you some troubleshooting tools. Please note, that if yo
ur OPC Server is not browsable, then the usefulness of the server explorer may be more limited.
After reading all of this, you should be able to simply read data directly from the plc registers by using datasocket and the correct url.
03-18-2002 11:12 AM
