Alignment problem: seems that the components shrink when open the same file in another computer
Hey, Have you experience that you aligned well on several arrays and its text lable, and lock them on one computer, andthey misaligned on another computer ?
Why?
(2,950 Views)
This is most likely due to different fonts. For example, if you have a VI that was written in XP and then you open that same VI on Vista, the front panel text will look different because Vista uses different fonts. This is a common problem and has been brought up numerous times. If you do a search you'll see the number of complaints, as well as suggested solutions. You will need to see which suggested solution works best for you since no one solution is the best.
(2,926 Views)
Hi Rosebud,
It could also the difference in resolution between the computers. Is the resolution different between them? If this is the case sometimes some features don't adjust (such as text).
Jeff | LabVIEW Software Engineer
(2,911 Views)
I figured it out. Both of the computers are under xp op. systems. But these two computers are under 2 different configurations of font size. That is reason.
Thanks for everyone.
(2,860 Views)
