Alarm Log module
i have to design an alarm reporting module.
in this, from acquisition module i will get the data and have to do some cases on that data and only alarm i have to logg.
for logging i will use text file
can u give me better idea about this
how i can design better it
Prashant Soni
LabVIEW Engineer
(3,650 Views)
what do you mean by "doing some cases"?
Would you like to perform the analysis when the data is being acquired or at a later stage?
Regards
Guru (CLA)
(3,643 Views)
Yes after getting data, i have to check about alarm and events
Prashant Soni
LabVIEW Engineer
(3,637 Views)
how are getting the data
If the data is populated from many channels, then index the rpw or column of the array and then perform a check for the alram or event. may be you can average the array data (for every iteration of the acquistion loop) and then compare with the set data
Regards
Guru (CLA)
(3,596 Views)
