Agilent Infiniium Scope Interface
I need step by step how I can interface with Agilent Infiniium MSO9104A Scope using LabVIEW 12 through the USB?, or any other way different than USB without buying any extra hardware
Also if there are any example files will be helpful
(2,634 Views)
If you have installed the driver from Agilent, then it should automatically appear in MAX as a USBTMC VISA resource. Go to Help> Find Instrument Drivers to install the LabVIEW driver. There will be at least one example.
(2,620 Views)
