Agilent E4980A configure correction
Hi All,
I am working on automation VI for Agilent E4980A.
I started from old sw compatible with the old LCR meter Agilent 428X.
I am trying to configure correction in the VI flow but I continue to have the following error:
Error -1074000000 occurred at Agilent E4980.lvlib:Error Query.vi
Possible reason(s):
Instrument reports:
+71,"Scanner I/F not installed"
+0,"No error"
below the old vi with the basic correction setup:
They look the same.
Do you have any idea of how to solve it?
Thanks in advance.
(1,751 Views)
The seems pretty clear that the instrument say something is not right. I would first check what Error +71,"Scanner I/F not installed" means in the User manual of E4980A and see what troubleshooting steps the manual recommends.
Santhosh
Soliton Technologies
(1,736 Views)
Hi Santo_13,
I checked also on user manual:
When Option 301 (Scanner Interface) is not installed and you attempt to switch to multiple
correction mode, a Scanner I/F not installed error message appears in the system message
area.
The fact is that I am trying to have a single mode, that's why.
Do you know any solution?
(1,708 Views)
