A client of mine needs to talk to an Agilent 81250 Parallel Bit Error
Ratio Tester using LabVIEW. Has anyone done this before? He has gotten
some info from Agilent that indicates that all communication to the
device must go through the "Firmware Server" application that runs in
the background, probably via ActiveX. But we could find no relevant
ActiveX component. Using standard VISA, I can see the various VXI
devices, but none of them are accepting the SCPI commands from the 81250
manual. Any ideas?
TIA,
Dave Thomson
David Thomson 303-499-1973 (voice and fax)
Original Code Consulting dthomson@originalcode.com
www.originalcode.com
National Instruments Alliance Program Member
Research Scientist 303-497-3470 (voice)
NOAA Aeronomy Laboratory 303-497-5373 (fax)
Boulder, Colorado dthomson@al.noaa.gov
