Agilent 34970A External Reference Configuration via Labview 8.2
Hello
I am trying to scan up to 12 channels with the Agilent 34970A. My goal is to measure the temperature using channel 101 as the external reference using 4-wire RTD whereas all the other channels are supposed to use Thermocouple (k-Type). I know that the Agilent is able to do so, because you can configure it on the manual display. My problem is that every time I have configured Channel 101 ( CONF: TEMP FRTD,85, (@101)) and then the other Channels 102:1XX ( CONF: TEMP TC,K, (@102:1XX)) it seems that the configurations for Channel 101 are lost. I tried everything I could come up with to seperate the inputs, but nothing usable comes up. Any Advice?
Thanks Neja
Message 1 of 1
(2,856 Views)
