After upgrading to Labview 2009 my project no longer rocognizes FPGA target
I have just installed LV2009 replacing LV8.6. For some reason my project tree is giving me a warning stating that the FPGA target is not installed or the plug-in has an expired license. The license manager indicates the license is valid and the Mesurement and Automation Explorer is finding the RT/FPGA just fine. Can someone tell me what I did wrong?
(2,503 Views)
Sounds like you neglected to install the FPGA toolkit for LabVIEW 2009.  You need to specifically select it when you start the installer, but you can add it in at any time, it does not need to be installed at the same time you do the initial LabVIEW install.
(2,502 Views)
You are correct. That's what I get for relying on someone else to properly install it. I got burned. Thanks for the help all is working now.
(2,499 Views)
