After installing PDA module only PDA Project available as target
It has been a while that I installed the PDA module for Labview 8.2 (which works just fine). I just noticed that now there is only one target available, which is "PDA Project". How do I create a VI that simply runs under Windows, like I used to do before?
(4,393 Views)
Hi _T_
From the "Getting Started Window" of LabVIEW 8.2, you can choose either a Blank VI or an Empty Project to work with your Computer. If you already have a Project open, then right-click on "My Computer" within the Project and select New >> VI. This will open up a VI which will run on Windows. Hope this helps.
(4,322 Views)
