After building application Serial Read does not work
Greetings,
    The vi works fine in interpreted mode but, once it is built into an application the Visa serial port read stops working(no data).
Message 1 of 13
(4,144 Views)
There is no such thing as interpreted mode. Do you mean the exe run on the same pc as where you have LabVIEW installed or on a different pc?
Message 2 of 13
(4,130 Views)
Sorry, I mean when I run the vi under Labview and not as an exe.
Message 3 of 13
(4,125 Views)
But is it on the same pc?
Message 4 of 13
(4,120 Views)
Yes, I built the exe from the vi on the same PC.
Message 5 of 13
(4,116 Views)
Of course you built the exe with the development system. What you still have not answered is where you are RUNNING the exe.
Message 6 of 13
(4,111 Views)
Sorry for the confution, I am running the exe on the same PC.
Message 7 of 13
(4,103 Views)
Thanks. What else does the VI do? Any file I/O? What sort of error message do you get?
Message 8 of 13
(4,099 Views)
There is a write to save the data to a file that is timed for every two minutes from a local variable.  The vi actually does a lot more and is used to control the temperature of a Thermal Vacuum Chamber.  All of the DAQmx works and reads back all of the TC data fine which is again periodically written to a data file.  The only thing that does not work after the build is the serial read from a vacuum gauge.  What is frustrating is that it does work before it is compile into an application.
Message 9 of 13
(4,095 Views)
I would suggest adding some error indicators and/or enabling debugging on the exe to see if some error is preventing the serial read from working.
Message 10 of 13
(4,090 Views)
