After Replace queue.llb and notifier.llb for LabVIEW 6.1, I can't use find examples.vi any more.
After Replace queue.llb and notifier.llb for LabVIEW 6.1, I can't use find examples.vi any more.Error list shows that SubVI 'EF-remove queue element with exit or error stop vi': subVI is not executable.
(2,765 Views)
You replaced them with what and why?
(2,765 Views)
I follow the statement posted here.
After replacing queue.llb and notifier.llb with newer version provided by NI, I can't use "find example.vi" anymore. Diagram of subvi was locked.
http://sine.ni.com/apps/we/niepd_web_display.DISPLAY_EPD4?p_guid=B45EACE3EA0756A4E034080020E74861&p_node=DZ52000&p_submitted=N&p_rank=&p_answer=&p_source=External
(2,765 Views)
I believe that by your action, you removed the compatability VIs and it would appear that the Find Examples used the older queue functions that require the compatability VIs. I would suggest you revert back to the LLBs that were distributed with 6.1. The new queue functions are there for you to use in new development and older VIs won't be broken. You could also make a request to NI support to see about an updated Find Example that uses just the new VIs.
(2,765 Views)
