Advantech USB 4704
I am currently working with the Advantech USB DAQ 4704 and aim to acquire data with a varying sampling rate between 100 Samples/second/channel and 2000 Samples/second/channel for two channels. The attached code is functioning correctly at a fixed rate of 2000 Samples/second/channel.
Could you kindly guide me on how to configure the following parameters to achieve varying sampling rates (e.g., 100, 200, 300, ... up to 2000 Samples/second/channel)?
  • Section Count
  • Cycles
  • Convert Clock Rate
  • Samples Per Channel
  • Section Length
Thank you in advance for your assistance.
Message 1 of 1
(876 Views)
