Advanced circle centre detection
Hello all,
I have a black image with a white circle (see attached), I need to find the centre and the radius as accurately as possible. As you can see the circle is not really nice and all the imperfections are on the inside part of the circle, this results in an under-estimated radius and the centre position error will depend on “how asymmetric” the imperfections are.
I have no particular experience in image processing so any idea will be greatly appreciated.
I was thinking of finding a centre with “IMAQ Circle Edge”, then drawing 360 radius from the centre (every degree), in order to do some statistics on their length.
This way I should get something like 70% of the radius with the same length (with just a few pix difference).
So my questions are :
 does it sound sensible ?
 if yes, what tool should I use to draw my 360 radius ?
 any other/better idea ?
Message Edité par TiTou le 02-28-2006 06:16 PM
Epictetus
Antoine Chalons
Message 1 of 8
(4,223 Views)
Hey Titou,
I don't have IMAQ.   If you can get x,y coordinates you can use "Fitting on a Sphere" to find the centre.
Message 2 of 8
(4,205 Views)
Thanks for the idea Jason, but my problem is more on how to get these points and also, the problem remains... if all the imperfections are on the inside part of the circle, the radius will be under-estimated.
thanks anyway for the idea 😉
Epictetus
Antoine Chalons
Message 3 of 8
(4,200 Views)
hi there
try this:
1. take all points with a value higher than a threshold (say 50% of the (maximum-minimum) in the picture)
2. get the mean x/y coordinates of these points
3. calculate the distance between the mean x/y for all the points above the threshold
4. select the (lets say) 10% of the points with the highest distance to the average x/y
5. pass the coordinates of these points to the "Fitting on a sphere.vi"
this gives you a center and a radius of a circle.
let us know.
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
Message 4 of 8
(4,194 Views)
Thanks for the idea Chris, I will try that and compare the result with what I mentioned earlier and let you know. 😉
Epictetus
Antoine Chalons
Message 5 of 8
(4,189 Views)
Hi Chris,
I will go for your solution, indeed the results appear to be better and above al, more reproductible ; I assume this is due to the fact that the other method uses calculations based on a centre position which is not accurate enough.
Thanks alot Smiley Wink
Epictetus
Antoine Chalons
Message 6 of 8
(4,169 Views)
hi there,
maybe a recursive calculation leeds to even better results (repeat the steps until center and radius don't change anymore)
Best regards
chris
Message 7 of 8
(4,166 Views)
Do you expect there to just be imperfections or are there some other issues like off axis rotation (rotation about the image plane) to worry about.  Using the mean value of the object pixels will yield a very good approximation of the center of a symmetric body.  I used this to find a quick center of a human form for a project in the past and even with the only loose symmetry of the human form it did quite well.  I circle should perform much better since it has full symmetry.  Additional hystoresis can help optimize the exact center of the circle.
Paul
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
Message 8 of 8
(4,160 Views)
