Advanced Plotting Toolkit Filled Contour Axis Format
Hi all
I'm plotting a filled contour using the Advanced Plotting Toolkit with one small hiccup - the X Axis values are displaying in a strange format. The X Axis values are being inputted as a 1D DBL Array in the following format:
527.100
527.101
527.102 etc
However if you look at the attached image they're displaying in a strange format, with 0, 0.02, 0.04, 0.06, 0.08 + 5.271e2
Can anyone explain why this has happened and how I would work around it? (The Y Axis is being displayed correctly)
Thanks!
Harry
(1,412 Views)
Did you also set axis limits? I think that can interfere with your tick marks.
(1,367 Views)
